It is currently Thu Sep 18, 2025 11:27 pm
 Post subject: dye to enhance curl
PostPosted: Wed Jul 22, 2020 7:18 pm
I think I recall a thread a few years back with methods to enhance to appearance of curl or other figure using subtle dyes. Please direct me to that, or chime in with current ideas.
 Post subject: Re: dye to enhance curl
PostPosted: Wed Jul 22, 2020 8:35 pm
First name: Chuck
Last Name: Skarsaune
City: Butler
I just did this on some figured maple that’s on an electric I’m building.
StewMac colortone dye (I used tobacco brown) in water, wiped over the surface.
This raises the grain so I sanded it back with 320. The dye absorbs more into the figure, kind of like it would on end grain. Sealed with some shellac and it has a couple coats of amber lacquer on it now. Let’s see if I can post a pic...
I’m pretty well pleased.
Sanding after dye runs the risk of being splotchy/uneven - this will be a burst so some of the surface will be covered in darker lacquer.
These users thanked the author Skarsaune for the post: wbergman (Wed Jul 22, 2020 11:58 pm)
PostPosted: Thu Jul 23, 2020 5:55 am
Be very careful using dyes or stains on figured maple. It's easy to kill the 'lively' nature of the figure and get the 'burnt in' look. Test on off cuts and make sure the figure continues to dance.
These users thanked the author Michael.N. for the post: wbergman (Thu Jul 23, 2020 2:42 pm)
PostPosted: Thu Jul 23, 2020 6:15 am
MIchael's suggestion is a good one. Or at least test on the other side of the wood. One can use different dyes to get varying effects. I have always done this with a sand back. The clears the stain on the hardwood, leaving the stain in the softwood, accentuating the difference. Leaving stain on the wood, without sanding back, will not maximize the difference in the grain.
Note that curl will pop once finished, so staining is not a necessary activity, but one that is chosen for certain circumstances.
These users thanked the author AndyB for the post: wbergman (Thu Jul 23, 2020 2:42 pm)
PostPosted: Thu Jul 23, 2020 10:41 am
Dye and sanding will enhance the curl/figure but it is a static and flat optical effect. On my personal instruments, I prefer to enhance the "chatoyance" with a "toner". Search on those terms if you want more detail.
These users thanked the author Barry Daniels for the post: wbergman (Thu Jul 23, 2020 2:42 pm)
PostPosted: Thu Jul 23, 2020 10:47 am
First name: Freeman
Last Name: Keller
I use stains on highly figured woods to highlight flame or curl, but if I don't want to add a lot of color I find that Zpoxy diluted with DNA does a great job of grain enhancement.
This one had a tiny bit of amber stain to give it the faded burst, then Zpoxy and DNA
Basically if you wipe the wood with naphtha and like what you see that will be about how it looks under the finishing resin
These users thanked the author Freeman for the post: wbergman (Thu Jul 23, 2020 2:42 pm)
PostPosted: Thu Jul 23, 2020 11:51 am
First name: Chuck
City: Butler
That looks great, Freeman.
PostPosted: Fri Jul 24, 2020 10:48 am
That's what I'm talking about. If you could see one of Freeman's guitars in person you would be able to see how amazing that kind of finish can be. As you move the guitar around the figure will appear dynamic. The highlights will move around as light hits it from different angles. I much prefer that over the dye/sand technique.
PostPosted: Fri Jul 24, 2020 10:53 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I too much prefer the 3 dimensional look to the shallower higher contrast look of the dye and sand back approach. I suppose it is a matter of preference and your goals. I generally prefer the natural color of the wood and finish to dyes and stains.
Bryan Bear PMoMC
PostPosted: Sun Aug 02, 2020 9:46 am
I used a little dye in my shellac on this Cherry/Cedar classical. Had to experiment a good bit to get it right.
PostPosted: Sun Aug 02, 2020 10:15 am
All these examples are gorgeous!
PostPosted: Sun Aug 02, 2020 7:34 pm
Last Name: Howell
City: Atlanta
State: Ga
I experimented years ago with birdseye maple and curley maple by dying black; sanding back 80% then yellow sanding back then fire engine red. But I have found most important is to prime with pure tung oil as initial finish.I then used blond shellac. But starting with oil based varnish also works. This was small boxes 25 years ago.
I liked the effect of black and yellow sanded back but reading here I see many other ways that look great on guitars. Beautiful wood
